Activity Forums Apple Final Cut Pro Legacy Do I have to have a 16:9 wide screen NTSC monitor to match my 16:9 timeline.
  • Do I have to have a 16:9 wide screen NTSC monitor to match my 16:9 timeline.
    Posted by Will Keir on April 7, 2006 at 2:33 pm
    Hello and thanks for responding to my post.
    I’ve been working on a project shot anamorphically, I’ve recently purchased a NTSC monitor, a basic TV, and suspect that the monitor has a slightly different picture.
    I’m well aware the sides are cut off, but I think perhaps there is a distortion as well resulting in my 16:9 footage looking squeezed.
    Does anyone know if my suspecision is correct and perhaps buying a 16:9 monitor is not the answer, but maybe there is an option in FCP 5 that I have not set/checked/unchecked?
    Thank you for any help,
    Will Keir
    Bill Dewald replied 20 years, 5 months ago 4 Members · 5 Replies
  • Ben Oliver
    April 7, 2006 at 3:06 pm
    hmm….more than likely yo uare looking at your picture squished….
    the only thing to “do” is to edit in a 4×3 timeline, so that your footage is letterboxed…..but that may tax your system a bit….and you’ll eventually have to render it out, and your final project will be 4×3 letterboxed instead of 16×9…
    -ben
  • David Roth weiss
    April 7, 2006 at 3:35 pm
    Will,
    Many/most broadcast monitors can be switched between 4×3 and 16×9, one of many reasons to use a true broadcast monitor. Your only solution on a 4×3 TV would be to either crop to 4×3, in which case you won’t see the full frame, or letterbox to see the full frame.
    DRW
  • Will Keir
    April 7, 2006 at 8:20 pm
    DRW,
    How, exactly, do I letter box my frame?
    Will Keir
  • David Roth weiss
    April 7, 2006 at 9:28 pm
    In this case Will you would simply edit your 16×9 material in a 4×3 timeline. Its not perfect, rather another one of those compromises…
  • Bill Dewald
    April 7, 2006 at 10:28 pm
    Or you can buy a basic TV that does 16:9.
    Toshiba makes one for $140:
    https://www.tacp.toshiba.com/televisions/product.asp?model=14AF45
    Even takes component ins.
