Activity › Forums › Adobe Premiere Pro › Do I edit in 4k then export to HD or edit the 4k in HD timeline?
  • Do I edit in 4k then export to HD or edit the 4k in HD timeline?
    Posted by Anthony Sneed on June 3, 2017 at 9:08 pm
    I have a project where about half of it was shot in 4k or above and the rest is in HD. There’s some parts where I blow up some of the HD so I think my final output SHOULD be HD. It’s a short film and I plan on taking it to festivals.
    Should I bring the 4k footage into the HD timeline then just scale it down, or should I edit in 4k, then in the end out to HD?
    Does it matter or is it exactly the same?
    Anthony Sneed replied 9 years, 4 months ago 3 Members · 3 Replies
  • Shane Ross
    June 4, 2017 at 8:31 am
    Editing 4K in an HD timeline means you can scale the 4K better…zoom in if you need. If you edit in a 4K timeline, you can’t do that, not without losing quality but scaling over 100%. If your deliverable is HD…or even 2K DCP…edit in those frame sizes. Edit in the deliverable frame size.
    Shane
    Little Frog Post
  • Ann Bens
    June 4, 2017 at 11:09 am
    Downside to this when wanting to use Warp Stabilizer you will have to nest first.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Anthony Sneed
    June 4, 2017 at 6:44 pm
    Cool thanks for the advice
