Activity Forums Adobe Premiere Pro Do Different Sequence editing modes really Matter?
  • Do Different Sequence editing modes really Matter?
    Posted by Rich Kaelin on December 8, 2015 at 3:22 am
    So, We recorded some footage at the camera and via SDI out onto a NanoFlash unit. The NanoFlash should be an XDCAM codec, but with 422 color at 50 Mbit, verses the camera which is XDCAM EX 420 @ 35 Mbit.
    If I take a clip from each and drop them into the New sequence area below, which should crate a sequence with the most appropriate settings for the footage, the camera XDCAM EX @ 35Mb footage yields a sequence set to editing mode set to AVCHD 1080p square pixel. The NanoFlash XDCAM EX @ 50Mb footage yields a sequence set to editing mode set to AVCiIntra 100 1080p 60Hz.
    Neither of these match any of the XDCAM setting I would have defaulted to, but does that matter? At the end I will just have to export the sequence to a different format, like prores or MP$. Would it ever really matter. This has me a bit confused. Is there a good explanation available of how these presets work and how choosing one could positively or negatively impact work flow anywhere?
    On a side note, all of the time code on the NanoFlash seems to be about 6.5 seconds late compared to the camera…once I find a visible match, the camera has a TC of 1:00:00:00, the nano will record a TC of 1:00:06:14 for the same frame. Time code is embedded in the SDI, used to trigger nano recording. any guesses why this happens? Just curious.
    Rich Kaelin
    Kaelin Motion Production Services
    https://kaelinmotion.com
    New York
    Rich Kaelin replied 10 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
