Activity Forums DVD Authoring Do CSS and Ripguard conflict?
  • Do CSS and Ripguard conflict?
    Posted by Alison Stevenson on September 15, 2006 at 7:07 am
    I’ve just sent a master with CSS to the replicator. The producer tells me she’s asked them to add Ripguard. Is there a possibility of a conflict between these copy protection schemes?
    Yes, I know you can defeat both of them.
    Alison
    Stable Recordings
    Scotland
    **better a has-been than a never-was**
    Dave Goodbourn replied 20 years ago 4 Members · 6 Replies
  • Account Closed for policy violations
    September 15, 2006 at 8:15 am
    You’re good, Alison,
    RipGuard is designed to protect the CSS encryption. No CSS, no need for RipGuard, in other words.
    Take care,
    Trai Forrester
    TFDVD Research Labs
    DVDVerification.com
  • Alison Stevenson
    September 15, 2006 at 8:48 am
    Thanks Trai. Just what I needed to know.
    Alison
    Stable Recordings
    Scotland
  • Noah Kadner
    September 15, 2006 at 3:13 pm
    Trai- is it possible to put CSS, Macrovision and Ripguard onto one disc or is one or the others more effective?
    Noah
    September 15, 2006 at 5:44 pm
    Hi Noah,
    Yes, you can put those three schemes onto the same disc. Each are designed to plug a different ‘hole’, and they don’t conflict. Macrovision requires the same 2054 byte sector sizes as CSS formatting does, so usually CSS and Macrovision go together when analog protection is implemented.
    I remain neutral on the issue of copy protection. If the client wants it, that’s their prerogative and you won’t hear a peep out of me (the folks who are going to rip and copy will do so easily, no matter what our thoughts are on the matter 🙂
    Though, I might let out that there’s no way I’d put Macrovision on any DVD; I’ve seen too many TV’s undulate bright and dark while running a DVD with it!
    Take care,
    Trai
  • Noah Kadner
    September 16, 2006 at 4:50 am
    Cool- I hear you on Macrovision. Maybe I’ll just go with CSS and Ripguard. Not too worried about the hard core rippers just casual copiers who should know better.
    Noah
  • Dave Goodbourn
    September 20, 2006 at 10:26 am
    Hi Alison,
    Just a note of caution, you might want to get the manual for Ripguard as you have to adhear to a few small guidlines. Nothing to worry about if the DVD is pretty standard (as in a feature, with some menus) but if the DVD is a complicated iDVD or the likes, Ripguard can become more visual, as they use a lot of dummy black cells in titles.
    Cheers,
    Dave.
