Activity Forums Adobe After Effects DNxHR 444 or HQX export
  • DNxHR 444 or HQX export
    Posted by Rainer Bergomaz on June 3, 2016 at 8:05 am
    I am working with AE CS6 and AE CC 2015. I want to export 4K DNxHR 4:4:4 or DNxHR HQX in a Quicktime container.
    Project settings are on 16 Bit.
    I am able to select the DNxHR HQX or 444 codecs in the Quicktime options. But in the output module trillions of colors is disabled. Doing the same with DNxHD codec and 10 Bit works (trillions of colors is not disabled).
    How can I export the DNxHR 444 or HQX codecs?
    Charles
    Walter Soyka replied 9 years, 11 months ago 2 Members · 6 Replies
  • Rainer Bergomaz
    June 4, 2016 at 9:12 am
    Thank you, Dave. As I wrote the bit depth of the project is 16 Bit. And DNxHD HQ (10BIT) export works with trillions of colors. It is only DNxHR where I cannot get HQX or 444????
    Please could you try it with your AE?
    Thank you
    Charles
  • Walter Soyka
    June 6, 2016 at 6:20 pm
    I can’t get DNxHR to do 10-bit output, either (CodecsLE_2.7.1_Win.zip). I’d suggest you file a bug with Avid.
    Adobe will be about to write MOV-wrapped DNxHR soon [link], and hopefully their implementation will be 10-bit.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Rainer Bergomaz
    June 8, 2016 at 10:23 am
    Deat Walter,
    thank you so much. Any idea how to let Adobe know about this bug?
    Charles
  • Rainer Bergomaz
    June 8, 2016 at 10:34 am
    Walter,
    any idea how to get the info when this new wrapper will be released?
    Any blog which I can follow?
    Charles
  • Walter Soyka
    June 8, 2016 at 11:11 am
    [Charles Binn] “thank you so much. Any idea how to let Adobe know about this bug?”
    You can report a bug to Adobe here:
    https://www.adobe.com/products/wishform.html
    But I suspect that this is Avid’s bug to fix. Apparently you report bugs to Avid by writing a forum post on their community site, which a moderator escalates if it’s a non-user issue.
    Walter Soyka
  • Walter Soyka
    June 8, 2016 at 11:13 am
    [Charles Binn] “any idea how to get the info when this new wrapper will be released? Any blog which I can follow?”
    Adobe’s blogs for the Digital Video & Audio applications are collected here:
    https://blogs.adobe.com/creativecloud/dva/
    Walter Soyka
