Activity Forums Avid Media Composer DNxHD to QT h.164
  • DNxHD to QT h.164
    Posted by Mmromo on September 1, 2005 at 7:10 pm
    Ok, so I’m going to work on our Avid Adrenaline with Avid DNxHD. I need to output to Quicktime h.264. Any recommendations on acquisition? Should I shoot DVCPRO HD or HDCAM. Does it matter?… why?….help! Thanks!!
    Michael Phillips replied 21 years ago 2 Members · 3 Replies
  • Michael Phillips
    September 1, 2005 at 8:47 pm
    You shoot either DVCPRO HD or HDCAM based on the advantages and disadvantages of those formats; look, resolution;, color space, etc.
    DNxHD itself does not care – it is designed to retain the full quality of all HD formats throughout the post process ensuring a mastering quality image. From there you will make your farther compressed delivery formats.
    Michael
  • Mmromo
    September 1, 2005 at 8:58 pm
    Does it matter that I’m outputting to Apples Quicktime H.264 – which is 24P?
  • Michael Phillips
    September 1, 2005 at 11:48 pm
    H.264 does not have a defined frane rate, it encodes to the frame rate of the source material. If your source is 24p, then your encode will be 24p.
