Activity Forums VEGAS Pro DNxHD (.mov) Vegas 12 problem
  • DNxHD (.mov) Vegas 12 problem
    Posted by Edmundo Ferreira on January 17, 2013 at 10:40 pm
    I chose Vegas 12 to edit a stereoscopic project. I work with Windows 7, i7, Nvidia GTX 680, 32 gb ram. There are two WD 3tb discs connected with USB 3.0. I was editing perfectly the original footage (mov, DNxHD) but when I get to, more or less, 20 minutes at the timeline, everytime I import a new left or right clip to make the stereoscopic pair (subclip), my preview turns black and every clip from the external drives will not appear there, only some clips that are in the system hard drive, in a partition. I’ve tried everything, including reinstaling Vegas or Quicktime. I’ve removed codecs, made a system restore, tried with and without gpu acceleration, turned off the “media offline” thing. What do have I to do? Make two projects for a movie?
    Salut
    Dave Haynie replied 13 years, 8 months ago 3 Members · 3 Replies
  • Mark Barton
    January 18, 2013 at 12:27 am
    You might be putting too much strain on the USB 3.0 bus. It is interrupt driven unlike firewire. When you cannot view the clips on the external drives within Vegas, is that also true from Windows Explorer? If so, then it looks like those drives/USB interface are the problem. When I was having some similar issues with my USB 3 external drive and finally just added another sata internal drive to use.
  • Edmundo Ferreira
    January 18, 2013 at 1:10 am
    Thanks for your answer. And yes, it’s also true for the windows explorer. I’m getting crazy with this…
  • Dave Haynie
    January 18, 2013 at 7:29 pm
    This sounds more like a hardware problem, related to your USB 3.0 controller, or the controller in your USB 3.0 drive.
    There’s really no such thing as “putting too much strain” on a hard drive. They’re meant for that. USB is plenty efficient these days. Yes, it’s true that USB drives can’t initiate transfers (technically speaking, Firewire drives can, as could SCSI before them). But basically what happens is that your PC starts a USB transfer, the USB controller uses bus-mastering DMA, just as Firewire or SCSI would, and as the transfer progresses, the USB controller interrupts the processor. This is, in fact, exactly the same kind of thing that happens with PATA and SATA.
    And of course, on USB 2.0 drives, the link is slower than many drives, so you had lots of waiting. But there is no situation in which a properly functioning USB drive would just lock up. USB 3.0 is actually faster than any HDD is going to be, so it’s going to moving data faster. But it’s designed to do that, all day, every day. So if it’s the drive or the controller, that’s an implementation problem. First thing I’d do — update all USB 3.0 drivers.
    Second hypothesis… maybe it’s not the drive. I know DNxHD is fairly hard core, size wize (usually 144Mb/s or so), so try a little torture test: put some uncompressed or Huffmann encoded HD video out on the drive. Beat it up just as you did the DNxHD. If it’s working, that suggests a problem with the DNxHD CODEC (which, last I checked, hadn’t been updated in ages) or Quicktime (running the latest version?). Anyway, places to look for a fix.
    -Dave
