Activity › Forums › Adobe Premiere Pro › DNxHD export
  • DNxHD export
    Posted by Derek Andonian on March 16, 2012 at 11:49 pm
    I’ve read several posts on here that said PPro can export DNxHD simply by downloading the codec from Avid. That sounded like it could be very helpful, so I decided to try it. But no matter what settings I use, Media Encoder gives me an error message and doesn’t encode at all, which is very puzzling. Do I need to have an Avid product installed in order to use it?
    ______________________________________________
    “THAT’S our fail-safe point. Up until here, we still have enough track to stop the locomotive before it plunges into the ravine… But after this windmill it’s the future or bust.”
    Jeff Brown replied 14 years, 6 months ago 3 Members · 2 Replies
  • John Pale
    March 17, 2012 at 5:41 pm
    It most certainly can encode. You probably have made an error in settings. check every single one to. Make sure they make sense.
    Two other things: unlike Apple Pro Res, Avid DNX is only for HD. In addition, you must use standard broadcast frame sizes and frame rates. You can’t customize at all.
  • Jeff Brown
    March 19, 2012 at 1:29 pm
    I can also confirm it works fine for encode and import, without any Avid hardware.
    You are accessing it via QuickTime, yes?
    -Jeff
