Activity Forums Adobe Premiere Pro DNxHD color accuracy in VLC
  • DNxHD color accuracy in VLC
    Posted by Darryn Rogers on June 16, 2018 at 8:03 am
    Not strictly a Premiere question but I’m hoping there’s someone here who can help.
    I’m wondering if anyone has any advice about getting accurate color display of DNxHD footage within VLC player.
    After a few hours of Googling and tooling around I have now managed to display ProRes renders in VLC consistent with Premiere (See the top two images in the screenshot) but when I compare a DNxHD render in Premiere with the same DNxHD in VLC the result is very different (See the bottom two images in the screenshot).
    Is this just a limitation of VLC? I’m trying to get a workflow happening on my new Windows machine. Should I just go back to my old Mac and ProRes? It’s very tempting right now.
    Windows 10
    Premiere CC 2018
    VLC 3.03
    Nvidia GeForce 1080Ti
    Edit
    After some further exploration I have managed to partially solve my own problem. It seems that VLC does not display the colours of the DNx RGB 444 1080p preset available in media Encoder. I tested the other DNxHD presets available in Media Encoder and they displayed accurately in VLC. Guess I’ll just stick with those.
    Greg Janza replied 8 years ago 4 Members · 5 Replies
  • Greg Janza
    June 16, 2018 at 5:35 pm
    Do you have a broadcast monitor that you can check your image with?
    I’d recommend that you add one into the mix by adding a blackmagic card or Aja and then you can have full confidence in your outputs.
    And since you’re on windows I’d also recommend Potplayer instead of VLC.
    Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
    Adobe CC 2018 |Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
  • Darryn Rogers
    June 16, 2018 at 10:03 pm
    Thanks Greg.
    Hardly anything I do goes out to broadcast these days so I don’t want to invest in a broadcast card and monitor but I will look into Potplayer as an alternative to VLC.
    Cheers
    Darryn
  • John Heiser
    June 19, 2018 at 9:33 pm
    “Broadcast monitor” is used here as a synonym for “reference monitor.” Professional reference monitors (Flanders Scientific, TV Logic, Sony, etc.) have superior electronics and hold their alignment/calibration very well. They run anywhere from a few thousand US$ to tens of thousands. If you want to know what color something really is, you use a reference monitor.
    That said, most people don’t have the money for a reference monitor (and the small hardware interface to feed it), so a good HDMI monitor can substitute, as long as you keep it properly calibrated. In the past, the HP Dreamcolor had a good reputation. If color is critical, you get what you pay for.
    John Heiser
    Senior Editor
    o2 ideas
    Birmingham
  • Simone Cabasino
    August 28, 2018 at 1:26 pm
    Are you able to use VLC with Decklink 4k Mini Monitor?
  • Greg Janza
    August 28, 2018 at 5:01 pm
    No, VLC is only for computer playback. The Decklink 4k Mini Monitor works with external monitors.
