Activity Forums Apple Final Cut Pro Legacy DNxHD changes frame size when imported to FCP?
  • DNxHD changes frame size when imported to FCP?
    Posted by Illusia Sarvas on January 18, 2012 at 12:22 pm
    Hi guys,
    I just ran into a weird problem. I hope the solution is simpler!
    I got a mov from an Avid user, in DNxHD codec. If I check the size in Quicktime player, everything seems to be fine – 1920×1080 as it should be. How ever, when I import the file to FCP 7.0.3 the size in browser says 1024×576. The file should be HD as far as I know, but for some reason FCP turns it to SD? I’m confused! (And yes, I do have the plugin from Avid, though every once in a while FCP complains it cannot read the codec…)
    I already asked the sender to check their export settings, but yet I find this very weird, because other clips they have sent me seem to be just fine. Any ideas?
    BR,
    Illusia
    Illusia Sarvas replied 14 years, 3 months ago 2 Members · 3 Replies
  • Illusia Sarvas
    January 18, 2012 at 12:43 pm
    I’ll reply to myself. Managed to work around this problem by converting the file to ProRes in Compressor.
    Still confused though, if you have any ideas, please tell me!
  • Michael Gissing
    January 18, 2012 at 11:35 pm
    Quicktime is never a reliable way to check file info. Usually FCP is so it sounds like you were sent a PAL SD file in true 16:9 not PAL SD anamorphic.
    Another way to check is to have VLC player on your system. It is a free player and much better at giving you accurate codec, frame size and frame rate info.
  • Illusia Sarvas
    January 19, 2012 at 8:33 am
    Hi Michael, and thanks for your answer.
    I just checked the clip with VLC player as you suggested, and it says it’s 1920×1080. As did Compressor by the way. FCP is the only one that disagrees…
    My problem was actually solved after they send me yet another clip. I don’t know what they did differently with the export, but this time the clip was fine and I could use it normally in FCP.
    Is there a clear list of settings one should use when exporting from Avid to FCP? And if there is, where can I find it?
