Activity › Forums › Avid Media Composer › DNxHD ?? which res to import as for DVD output
  • DNxHD ?? which res to import as for DVD output
    Posted by Alan Howard on May 25, 2013 at 11:10 am
    I’m working with canon XF305 footage and will be delivering on DVD but would like the option to keep the master as full HD for archive. My plan is to create the timeline full HD, output a QT Ref to Sorenson and let that do the down res to SD DVD, leaving me with a high res master.
    My workflow involves importing the Canon footage but I’m unsure what would be the best res to import as… DNxHD 85,DNxHD 185 or anywhere in-between?
    Is there major space saving advantages with lower res? Will someone who’s not a fully trained broadcast QC inspector see any difference?
    FYI I’m importing as opposed to consolidating because I’ve done that before with AVCHD and it worked fine (Canon is MXF tho … should be simple fast import??) I know there are advantages to consolidating but I’ve not come across an explanation that I fully understand! If someone can point me to a dumb ass simpleton explanation I’d be very grateful…
    Cheers
    Alan
    Fred Jean replied 13 years, 4 months ago 3 Members · 2 Replies
  • John Pale
    May 25, 2013 at 2:16 pm
    You did not specify the format you are shooting in. . If you are shooting 1080i or 1080p @ 29.97, I would use DNX 145. 220 is probably overkill.
    If you are in PAL land or shooting 23.98/24, the DNX numbers will be different, but generally the second highest number will be fine, No harm in going to the highest level, but will give you a bigger file with little to no visible difference in quality. Do a quality test if you are unsure. Some material compresses better than others.
    You can AMA link and transcode rather than import. It’s much faster…but if you would rather import, go nuts.
    I would not work native with AVCHD, as I’ve had very poor experience with that. Transcoding is the way to go,
  • Fred Jean
    May 25, 2013 at 3:11 pm
    Totally agree.
    Working avchd native is to be avoid, although very fashionable those days, unless there is good reason for it: little volume, fast turnarround requiered.
    Also true that there is a point where it’s virtually impossible to see a visual difference between codecs so not necesarly is required to jump to the very
    Highest. But it would also depend very much on how far are you going to affect the image in post. The more CC and compo needs, the highest codec.
    As the transcode time is the same for dnxhd…
    The way you want to use squeeze is a correct one. Better to just do qt references, way faster, and let squeeze doing the job instead of blocking Avid.
    But keep in mind (this is a doubt I had and asked in this forum) that Avid does not automaticaly point to the highres material if you want to transcode from proxies. You have to conform first. It’s not a complain, logical and expected but it could have been different. In other
    Words, the app does not take
    Into account the hierarchy of the
    medias, it just transcodes what
    You give it.
    On Ama…big debate.
    It sounds faster just ama and start
    To edit. However, what’s faster
    On the paper can become the big
    Hassle very soon.
    I use ama for storyboarding, reviewing.
    For editing, I want dnxhd 36.
    There is a reason for that: stability.
    I can collapse an edit and work
    With gazillion effects and tracks,
    No freeze, no crash. No rendering.
    When all that is booked, conform the
    Sequence to the highres media.
    If I did that with amaed avchd
    Of even prores 444 from Alexas,
    I’d need the Pentagon computer power.
    Same in a compo app. One do not
    Just grab a codec material and
    Ingest that into Nuke. No. It would
    Work for simple tasks but if you
    Want to do serious compo,
    You want to feed Nuke with sequence
    Of exr ir tiffs. Same with edits:
    Serious edit requieres stability
    And proxy workflow.
    So Yeah, working with proxies
    Always is more step,
    But it’s worth.
    And It’s even worth transcode
    Your avchd footage into 2 flavours
    Of dnxhd: One high-res and the proxies.
    And that’s where ama is usefull.
    Why doing 1 highres transcode?
    Because avchd aint prores444.
    It falls apart at the minimum CC.
    Can’t be considered as a stable
    Highres media.
    Fred.
