Activity Forums Avid Media Composer DNX-HR codec and Quicktime Issue
  • DNX-HR codec and Quicktime Issue
    Posted by Michael Buday on November 2, 2016 at 10:46 pm
    I’ve finished a show at UHD rez/23.98 using the DNX-HR codec (Avid v8.6.4 for Mac / 10.11.5 (15F34)). The timeline clips consist of a wide variety of source material, from 4K to 720P. Everything has been rendered on the timeline to DNX-HR.
    My process to get o other formats is as follows:
    a) Output QT file from AVID using SAME AS SOURCE (DNX-HR)
    b) Take QT file from AVID and using AMC (Adobe Media Encoder, latest CC version), encode to desired format (MP4, DCP, whatever . . )
    My issue is this:
    The QT looks fine (though with the typical AVID black level change). But after processing thru AMC to say, MP4 – some clips in the SEQ don’t encode correctly, instead they appear filling the screen with an ORANGE color.
    Has anyone seen this behavior before?
    – Michael Buday
    Michael Phillips replied 9 years, 10 months ago 2 Members · 3 Replies
  • Michael Phillips
    November 3, 2016 at 2:59 am
    I stay away from anything wrapped QuickTime (.mov) as it is not the codec that causes level/gamma issues, but the wrapper. I have tried eliminating any use of QuickTime whenever possible and use OP1a exports. See my blog for reasons why:
    https://24p.com/wordpress/?p=278
    Michael
  • Michael Buday
    November 3, 2016 at 4:33 am
    Hi Michael,
    THANK YOU!! This makes a ton of sense and in my tests it worked beautifully. I only wish I inquired sooner as I’ve been using the AVID > QT > “Desired format” method for a very long time.
    Question:
    My sequence contains a TON of AMA referenced 4K material from Sony A7sii cameras. I offlined at 1080P/23.98, all media transcoded to DNX-LB. I then imported the sequence into a new UHD project setup for DNX-HQX, consolidated the timeline and imported all the AMA references to link up to the original media.
    Of course, the timeline won’t play 4K XAVC-S AMA media without slowing wayyyy down, so I rendered the entire sequence so I could play it to eval the uprez.
    Using your AMA OP1a export, If I export to the same codec the sequence has been rendered to, does it re-render again before exporting? Or does it reference the “already” rendered material?
    Thanks again – extremely helpful.
    – Michael
  • Michael Phillips
    November 3, 2016 at 1:20 pm
    That’s a good question and one I do not know the answer to as to what exactly goes on under the hood. From a quality perspective, the DNx codecs can go many generations before showing any type of decompress/recompress artifacts. From a time perspective, it would go faster if it did not have to decompress/recompress, but in my tests it is still doing whatever faster than any other export method when you combine all the steps needed to do the other export types.
    Michael
