Activity Forums Avid Media Composer DNX File & Animation Codec on MAC
  • DNX File & Animation Codec on MAC
    Posted by Sascha Engel on May 16, 2011 at 6:50 pm
    Hallo,
    and another AVID Question from the FCP user side of the river:
    I received an OffLine Final / Export from an AVID system.
    It was handed to me in three different codecs:
    1.QT Animation
    2.QT dnx
    3.QT ?5? (not sure which codec exactly, the file was named 5)
    Unfortunately the Animation Codec is the only one that can be read by my MAC system.
    The DNX File and the other one is nor regocnized by FCP, AE or MPEG Streamclip or any other compression or transcoding software.
    Why is that?
    I heard DNX is quiet a good codec, and it’s much smaller than Animation.
    Could somebody, please, explain.
    Thanx a lot.
    Greetz,
    Sascha
    Dan Marlow replied 15 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    May 16, 2011 at 6:57 pm
    To view DNxHD, you need to install the codec onto your system. It can be downloaded from here:
    https://www.avid.com/US/industries/workflow/DNxHD-Codec
    Shane
  • Sascha Engel
    May 16, 2011 at 7:04 pm
    Thanx Shane – wow, you are fat!
    You have a direct line to COW implanted in your brain 😉
    Very good!!! It works.
    Sascha
  • Sascha Engel
    May 16, 2011 at 7:29 pm
    Oh my god, did I really write Fat???????
    Sorry, typo – I meant FAST.
  • Shane Ross
    May 16, 2011 at 7:45 pm
    I thought you meant to type “PHAT.” Which is a good thing.
    Shane
  • Sascha Engel
    May 16, 2011 at 7:54 pm
    Well, Phat you are certainly – just wanted to make sure you didn’t get it as fat in the classical sense ;-).
  • John Pale
    May 17, 2011 at 3:49 am
    Does this codec make my pixels look fat?
  • Dan Marlow
    May 23, 2011 at 9:52 am
    Sorry if this is a silly suggestion, but have you downloaded the latest Avid l.e Codec package? Its free from Avid and will allow playback of DNX Qts on your mac. It will then be usable in your compression software.
    From there you can probably find an equivalent pro-res setting maintain the bit-rate of the original as pro-res is essentially Apple’s version of DNX.
    Hope this is helpfull.
