Activity › Forums › VEGAS Pro › DNG RAW workflow (Magic Lantern) Sony Vegas Pro 13
  • Russ Froze
    September 2, 2014 at 5:55 pm
    Before I give the url I must explain that dng files in Vegas are slow, but it does work and many things can be accomplished. I use 32-bit floating point (video levels) in the Project Properties. As for the clip properties, the color space I leave as default but you can scroll through the setting to see what works best for you. Another easier workflow is to unpack Magic Lantern raw files with MlRawViewer. It can output a dng sequence or a quicktime mov with Apple prores at 422 a very nice codec that works well in Vegas. White balance, color space or lut can be applied while unpacking. If using mlv in Canon, it will synchronise audio for you that is if you recorded audio. The link to the Adobe DNG code is https://www.adobe.com/support/downloads/detail.jsp?ftpID=5495
    If interested in MIRawViewer the link is https://bitbucket.org/baldand/mlrawviewer/downloads
    At present I’m using version 1.1.6 it seems stable also it’s a good idea to go to the overview page and get a copy of the keyboard shortcuts. Most of the function are accessed by keyboard shortcuts. Hey it’s free. Let me know if it woks for you.
    Russ Froze
Page 2 of 2
