Activity › Forums › Adobe Encore DVD › DLT drive not recognised
  • DLT drive not recognised
    Posted by Baz Leffler on July 11, 2005 at 11:52 pm
    I have 2 totally separate computer systems running Adobe Encore each with Quantum DLT4000 drives. In both systems the DLT drive is not recognised by Adobe Encore but show up in the device manager. They also test OK using Xtalk… so… anyone else had this problem and found a solution?
    Baz Leffler replied 21 years, 2 months ago 2 Members · 2 Replies
  • Dave Friend
    July 12, 2005 at 2:36 pm
    BZ,
    I had the same problem. The solution was to reinstall Encore with the DLT drive connected and turned on. It seems that Encore assumes that if the DLT isn’t there at the install it never will be. Dumb.
    Dave
  • Baz Leffler
    July 13, 2005 at 8:29 am
    Thanks Dave but I had already done that to no avail….
    cheers
