Activity › Forums › Adobe Encore DVD › DLT 4000 not found
DLT 4000 not found
Posted by Craig Townsend on January 21, 2006 at 7:54 pmI originally bought Encore(1.5.1) for it’s DLT support but found it won’t even see my Drive(Quantum 4000) which I just recently bought. The drive works fine when backing up in XP(SP1 and now SP2) using XP’s Backup or NovaBackup. I’m using the onboard SCSI on my Supermicro X5DA8. I don’t really want to try using other controllers since all of my slots are used up and it shouldn’t be necessary anyway since the onboard controller has worked fine with everything. Thanks.
Craig Townsend
Innovative Video ProductionsCraig Townsend replied 20 years, 8 months ago 6 Members · 22 Replies -
Dominic Osborne
January 22, 2006 at 1:33 amHey,
I can tell you that the DLT4000 works absolutely flawlessly in my system, in Encore 1.5 and 1.5.1.
Perhaps go to the Quantum site and make sure you ahve the altest firmware for your drive – you’ll have to dig around as obviously it’s not manufactured anymore. If your drive is not badged as Quantum, then as far as I understand, it actually pretty much is just a quantum drive with a different badge.
I have read that making sure the drive firmware is up-to-date can solve this kind of issue.
Dominic Osborne
Director & Head of Visuals
Eight Eyed Sea Bass Ltd
http://www.eighteyedseabass.com -
Craig Townsend
January 22, 2006 at 5:25 amThanks for the reply Dominic. I followed your advice and found that Quantum had newer drivers as well as newer firmware. I installed both but still have the same result. My gut feeling tells me that Encore doesn’t like the onboard Adaptec controller on my X5DA8 motherboard but I could be wrong. There are some other people having similar problems(DLT drive works with anything but Encore) so it appears that Adobe is doing something differently than others for some reason. Apparently DVDit 6 Pro doesn’t have problems for some of those people so maybe I’ll have to end up changing apps. if all else fails.
Thanks again.Craig Townsend
Dominic Osborne
January 22, 2006 at 12:44 pminteresting….
my DLT is also connected via an on-board adaptec scsi controller….Dominic Osborne
Dominic Osborne
January 22, 2006 at 12:47 pmforgot to mention, my motherboard is also one of the excellent supermicro range… (P4DC6).
Dominic Osborne
Craig Townsend
January 22, 2006 at 3:41 pmThe X5DA8 does have a newer version SCSI controller but one would hope Encore wouldn’t be that picky, at least if it wasn’t trying to control the drive by itself. I would hope they go through Quantum XP’s drivers since we aren’t talking about any great speeds here. 🙂 The whole thing is very puzzling since it appears many people have no problem but apparently quite a number do(proportionally since most people don’t deal with replication).
Craig
Dominic Osborne
January 22, 2006 at 9:10 pmyep…. well, i can’t think of much else other than something obvious like ‘have you checked for newer drivers for the scsi hardware on adaptec’s site?’
If this doesn’t help, I could always ask you “is your computer switched on, sir?”
Dominic Osborne
Dominic Osborne
January 22, 2006 at 9:15 pmactually actually actually….
something in my mind… somewhere at the back there…. something is saying I’ve read that after updating the drive, you might want to try reinstalling Encore.I don’t know why I am remembering this… and I’d be perfectly happy to be pointed at and told I’m making it up….
May be worth a try anyway, it’ll only take 5 mins to find out.
Craig Townsend
January 23, 2006 at 1:06 amThanks for the idea- it was worth a shot- but no help. I did a full uninstall and reinstall of Encore but it still has no clue there is a drive attached. This install was done with the drive up and running to give it every chance of finding out there is one. Thanks again for trying to come up with something.
Craig Townsend
Innovative Video Productions -
Gene Colburn — email address bounces notices
January 23, 2006 at 1:20 amSomething that comes to mind, Go to control panel – computer management – services – Look at the list and see if the option for removable media might be in manual or disabled. I kind of rember having similir issue with win2k but not XP. The option is definately there though. There might be some other service there also that might be stopping media recognition.
Regards
GC -
Craig Townsend
January 23, 2006 at 3:57 amThanks for the help. I checked and did find a Service called “Removable Storage” but it showed up as already started. It was in “Manual” mode but I switched it to “Automatic”- it didn’t make any difference. I assume this was the Service you referred to since I didn’t see anything else similar.
Craig Townsend
