Activity › Forums › DSLR Video › DLSR to DG fastchannel
  • Brian Deviteri
    February 6, 2010 at 3:07 am
    As long as you’re not scaling drastically, you should be fine. Make sure any text is scaled properly and maintain sharp, vector-like properties (when desired).
    Are you planning on submitting to DG in SD or HD? What format? What format are you shooting? What FPS?
