Activity › Forums › Blackmagic Design › DL HD Ext 3D & old PAL VHS tapes
  • DL HD Ext 3D & old PAL VHS tapes
    Posted by Peter Wicks on July 17, 2011 at 2:16 pm
    Hi, I would like to know which produces the best VHS capture quality:
    capturing PAL VHS tapes as component, uncompressed (10 bit) with BM’s input cables, using Media Express, then edit & render the uncompressed captured files with Prem Pro CS 5.5,
    or,
    run VHS from a player as S-VHS thru a Digital camera on the fly, to digitise it, (& get timecode) then captured into Prem Pro via firewire ?
    I tried the first method, had some signal drop out, (capture screen green), & with the good parts, got a poor result after edit & export, (which may have been my export settings). I would think component uncomp would be better, but not sure?
    Does Media Express’s uncompressed capture re-do new timecode ?
    thanks
    Peter Wicks replied 15 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
