Activity › Forums › Blackmagic Design › DL Extreme needing refresh after restart
  • DL Extreme needing refresh after restart
    Posted by Sean Lander on March 4, 2008 at 12:31 am
    I’m finding that even after updating to 6.6.3 that after every restart or shut down I need to open the control panel and select the downconvert option as well as the field jitter so that I can see full screen output on my SD monitor. Otherwise I just get garbled video craziness on the screen. Anyone else have this issue? It’s been there ever since I went to QuickTIme 7.4
    Cheers
    Sean Lander replied 18 years, 6 months ago 2 Members · 3 Replies
  • Kristian Lam
    March 4, 2008 at 10:24 am
    Hi Sean,
    Is the system profile you’ve listed in your profile still up to date? Trying to find out what kind of configuration you’re running so that I can get the guys here to check this one out.
    regards
    Kristian Lam
    Blackmagic Design
  • Sean Lander
    March 4, 2008 at 11:20 am
    Will update it now. But the system is Mac Pro Dual Quad Core with 4 Gb of Ram and Running a SATA 2 Raid. Final Cut Studio 2, QuickTime 7.4.1
    Cheers
    Apple Certified Final Cut Pro Trainer
    R E D N A I L – M E D I A
    https://www.rednail.com.au
    email: sean@rednail.com.au
  • Sean Lander
    March 7, 2008 at 5:43 am
    In snooping around through my system I noticed that I don’t have any Blackmagic drivers in my Startup items folder. Could this be the root of the problem?
