Activity › Forums › Blackmagic Design › DL Extreme for HDV Editing
  • DL Extreme for HDV Editing
    Posted by Robin on June 11, 2006 at 7:38 am
    I read in the DL support section that this is possible. I’ve ingested footage via firewire, but once footage is playing back, in the canvas and viewer video is running fine, but on the external monitor, it’s freezing on the start frame of the footage. Am I using the wrong setting (I’m currently using Blackmagic Decklink PAL 10-bit)? Please advise.
    -Robin
    Kristian Lam replied 20 years, 3 months ago 2 Members · 1 Reply
  • Kristian Lam
    June 11, 2006 at 8:08 am
    Hi Robin,
    You’re using the wrong setting. Use the HD settings and let the card do the down conversion.
    If you’ve shot HDV at 1080i60, use the easy setup “Blackmagic HDTV 1080i59.94 – HDV”.
    regards
    Kristian Lam
    Blackmagic Design
