Activity Forums Blackmagic Design DL Extreme capture only mov?
  • DL Extreme capture only mov?
    Posted by Meeroo Sareew on September 5, 2006 at 8:03 am
    I tried to capture some footage from DigiBeta to PC via DL Extreme card using Blackmagic Deck Control. The problem is that everything I capture is in .mov and I need it in .avi cause I have subtitling program that doesn’t work with .mov files. Am I doing something wrong here? I can’t find options in preferences where I can choose between .mov and .avi capture.
    Tnx
    M
    Meeroo Sareew replied 19 years, 12 months ago 4 Members · 5 Replies
  • Martin Kraut
    September 5, 2006 at 2:46 pm
    If you
  • Kristian Lam
    September 6, 2006 at 6:12 am
    Blackmagic Deck Control isa Quicktime based application and will capture to Quicktime’s .MOV format. If you need AVIs, use Adobe Premiere Pro which captures to .AVI.
    regards
    Kristian Lam
    Blackmagic Design
  • Brett Howe
    September 6, 2006 at 9:03 am
    so we will still have deck control through premiere?
    Is this the same for the multibridge line?
    Cheers
    Brett
  • Martin Kraut
    September 6, 2006 at 9:12 am
    Decklink VTR Control is included in APPro.
  • Meeroo Sareew
    September 6, 2006 at 3:10 pm
    ok, tnx
    m
