Activity › Forums › Apple Final Cut Pro Legacy › DJI Phantom 3 Standard footage in Final Cut Pro 7
Posted by Derek Smith on February 8, 2017 at 5:03 pmI have ingested my DJI phantom 3 Standard shots of buildings into Final Cut Pro 7 after converting from H264 to Pro Res
There is serious flicker- like serated edges on all lines which shimmer as the subject moves through
the frame . I’ve tried video filters and it remains . I’ve heard that there might be some Codec issues
has anyone had the same experience ? It’s driving me mad !
ThanksRoger Poole replied 9 years, 6 months ago 2 Members · 6 Replies -
Derek Smith
February 9, 2017 at 9:26 pmI think you’re right .
The original was I believe 1080 x1920 at 25pHowever every time I converted from H264 to Pro Res I got an Upper Field frame result and my sequence settings in my FCP timeline were None in field dominance , so I think this is why I’ve had the problem.
I converted the footage to XDCAM and this works without any of this terrible interference , although the definition seems lower than Pro Res 422 HQ.
I also tried dropping the Pro Res footage in an Upper Field setting timeline and it seems to work OK. but all my other material in the film is different so I can’t proceed .DJI just told me that the Phantom 3 Standard is not compatible with Pro Res . I might just carry on with XDCam .
Derek
Derek Smith
February 9, 2017 at 11:59 pmThanks , I’ve tried converting to progressive using Compressor but it won’t allow me to change the field – it keeps coming out upper field. I’ve also got Aiseesoft and iSkysoft both I’ve found difficult to use even though they cost a fortune!
neither allow me to control the field.
Maybe this is the compatibility problem of
the Phantom 3 codec . -
Derek Smith
February 10, 2017 at 10:16 amThanks for your work on this , much appreciated . It’s worth knowing about all these options, I only have Apple on my Mac so no Adobe Media Encoder sadly. At least I do have something I can work with,
but I wish manufacturers would let us know about these things before we spend our money ! -
Roger Poole
February 10, 2017 at 11:39 amI believe the DJI camera uses the Gopro chip so assume it records in the same format. For GoPro footage I use Mpeg streamclip, (free), to transcode. With Mpeg streamclip, drop a clip onto the window then choose convert to Quicktime. In the conversion options window which will now be open, choose, from the top, the codec you wish to use, I choose Proress 422HQ. Set the qualitity slider to full. There are lot’s of settings in there but all are ok as-is, except on the right where there is a button “deselect for progressive material”. Uncheck that and press go at the bottom. The resulting transcoded clip should be pristine.
Derek Smith
February 10, 2017 at 12:41 pmThanks Roger this worked . I’d tried my MPEG Streamclip earlier but I did the opposite of what you suggested and ticked all the boxes thinking the interlacing problem might disappear ! Unchecked I get as you describe a good result.
I’ve spent money on not very reliable converters recently and I still think the free MPEG Streamclip does a brilliant job.
