Activity › Forums › VEGAS Pro › DIY – NLE Vegas 10 System built from Videoguys
  • DIY – NLE Vegas 10 System built from Videoguys
    Posted by Jeff Green on July 9, 2011 at 11:21 pm
    Hi…I am new to posting here but have referenced your site from time to time. Very informative. To the point…I just built the DIY system #8 from the Videoguys website and I am not really seeing the benefit to this. Projects seem to render at same speed and contain the same issues as before. Here are the specs:
    ASUS P6X58D-E mobo
    EVGA GTX 570 with 2.5gb DDR5 memory
    i7 – 975 Extreme Edition CPU
    12gb DDR3 Crucial 1600mhz memory
    Momentus Hybrid 500gb system drive
    Corsair 750w professional PSU with single 12v rail (that was mentioned as being necessary in the Videoguys build out specs)
    My old system was another ASUS board, Quad Core 2.6ghz CPU, 8 gb DDR2 mem and a 150gb Raptor drive. The new system just doesn’e seem to be much faster if at all. Any ideas on what I might tweak?
    A million thanks!
    Jeff
    Stephen Mann replied 15 years, 2 months ago 5 Members · 12 Replies
  • 12 Replies
  • Scott Francis
    July 10, 2011 at 12:23 am
    What is you OS? If you are using XP or a 32 bit system, that could be your problem. I saw a HUGE difference when I went to Win 7 64bit…just a possibility..
    Regards
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • Jeff Green
    July 10, 2011 at 12:32 am
    Thanks Scott. I am using Win 7 Pro 64bit. I have been speakingwith a friend about this and he suggested that I need my media storage in Raid 0. Utilizing 4 HDD’s in Raid 0 and connected via eSata or Firewire. He believes that is where my bottleneck is coming from.
    I welcome any thoughts you may have. Thanks!
    Jeff
  • Scott Francis
    July 10, 2011 at 12:52 am
    What formats are you editing? HDV, SD, AVCHD?
    Scott Francis
  • Jeff Green
    July 10, 2011 at 1:09 am
    It’s AVCHD mostly from a DSLR. Full 1080 / 30p.
  • Scott Francis
    July 10, 2011 at 1:47 am
    That may be your issue, AVCHD is tough to edit….maybe try an intermediate format…I have AVCHD too and a hexacore system and it slows it down a bit too….I am looking at neoscene for conversion…good luck!
    Scott Francis
  • Jeff Green
    July 10, 2011 at 3:08 am
    Thanks Scott. Perhaps the Raid 0 Media Drive set up will do the trick. I have also heard that Cineform is a good idea. My thoughts were to build a system that was alot more robust than my last and that that would do the trick but apparently not. Thanks again for the info!
    Jeff
  • Stephen Mann
    July 10, 2011 at 5:35 am
    [Jeff Green] ” I have been speaking with a friend about this and he suggested that I need my media storage in Raid 0. Utilizing 4 HDD’s in Raid 0 and connected via eSata or Firewire. He believes that is where my bottleneck is coming from.”
    If you are editing uncompressed 4K HD. Everything else, a 7200 RPM SATA drive is fast enough.
    You don’t say *where* you are experiencing the “bottleneck”, but since you indicate AVCHD, I’ll assume it’s your preview that is less than perfect. Welcome to highly compressed editing.
    If yo are only doing simple cuts and dissolves, then an i7 is sufficient. Add any fx and even the mighty i7 Extreme will be challenged. Transcoding is your on;y solution for now.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Jeff Green
    July 10, 2011 at 3:46 pm
    Thanks Stephen. I am beginning to think you are right. I am thinking about Cineform for the transcoding. I have EpicDV right now but I am not sure it was the right choice. Seems a little cumbersome. Do you have a preference?
    Jeff
  • Larry Brewer
    July 10, 2011 at 4:05 pm
    Building a RAID 0 with 4 hard drives is a good idea. But my own experience suggests keeping the drives internal. If you use external and firewire, make sure it is 800. Esata is a lot better than USB but internal was overall a better choice for me. I say this after trying all the other choices.
    Your mobo has plenty unused sata connectors and your power supply is 750 watts, so all you need are the drives and a place to mount them.
  • Jeff Green
    July 10, 2011 at 4:42 pm
    Thanks Larry – I actually have eSata, USB 3.0, and firewire. So did you use the Raid 0 for your media files. Did you try the software (like Cineform) for transcoding as well as an option? Can you tell me more about your experience with the Raid 0? Like, what percentage faster was it? or how many more MBs/sec faster was it? I have punch outs in the back of my case that I believe are there to allow me to set up components outside the box and run the cable back in and directly to the motherboard. Do you see any options with that?
    Overall I like the idea of the raid 0 being in the box so I don’t have to buy another piece of equipment (i.e. the Raid Storage – they can be pricey), however, I am concerned about the heat build up.
    Thanks for your comments!
    Jeff
