Activity Forums Adobe After Effects Expressions DIY depth of field
  • DIY depth of field
    Posted by Nick Hill on January 8, 2010 at 3:16 pm
    My math(s) isn’t up to this.
    I have a camera pointing at a bunch of 3d layers to which I want to add depth of field. The default depth of field looks pretty horrible (they’re stark black and white so the box blur effect is obvious). I tried using the lens blur effect with a custom map, but when the layers move in 3d this stops working, plus it takes ages to calculate. So, I thought I’d improvise – applying a gaussian blur effect to each layer, than determining how much to blur it by its distance from the camera’s focal plane, multiplied by a slider value. It’s imperfect (and wouldn’t work for a layer that’s almost at 90 degrees to the camera of course, where the back is significantly further away than the front) but it’ll do.
    The problem is that I can’t work out how to calculate a plane which is normal to the camera direction (centred on the point of interest) and then the shortest distance from the target layer to this plane. Any ideas?
    Nick Hill replied 16 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 8, 2010 at 4:13 pm
    Something like this should work:
    mult = .1; // your blur amount slider goes here
    C = thisComp.layer(“Camera 1”);
    v1 = toWorld(anchorPoint) – C.toWorld([0,0,0]);
    v2 = C.toWorldVec([0,0,1]);
    d = length(dot(v1,v2),C.focusDistance);
    d*mult
    Dan
  • Nick Hill
    January 8, 2010 at 4:57 pm
    Thanks Dan! A maths wizard as ever 🙂
