Activity Forums Adobe Premiere Pro DivX/Xvid encoding problems
  • DivX/Xvid encoding problems
    Posted by Will Johnston on May 4, 2007 at 6:22 pm
    I can’t seem to get Divx or Xvid to work properly with Premiere. Every time I try to export a video, Divx creates artifacts all over my video, and Xvid simply locks up. I’ve messed with every quality setting I can find on Divx with no luck. I’ve set the bitrate to 3000 for a tiny 320×240 webcast, and the quality is still terrible. Any advice would be much appreciated.
    Will
    Matjusm replied 18 years, 9 months ago 4 Members · 3 Replies
  • Alex Jusay
    May 4, 2007 at 7:15 pm
    I think the best approach is to just render to avi then convert to divx using a different software, like procoder or dr divx. the latter makes terrific conversions.
    hope it helps
    jhalex
  • Dfocus
    May 15, 2007 at 9:53 pm
    The problem that premiere hangs when rendering xvid usually comes with the xvid status window. Uncheck the popup status window from the xvid configuration and it should render.
    /d
  • Matjusm
    December 9, 2007 at 9:44 am
    Where exactly is that little Xvid pop up unchecker? Because I’ve been having EXACTLY the same problems. It is not normal that a professional grade program like Premiere can’t handle a simple Divx export. I did a little test and the way it worked for me was that from Premiere I exported uncompressed .avi which I then converted to Divx using Sony Vegas (the reason I don’t use Vegas for editing here is because it freezes when I drop my clips on the timeline).
    But even though I got it to work, this isn’t the slightest bit normal. Why can’t all the different formats and codecs just get along and not give me such headaches?
