Activity › Forums › VEGAS Pro › DivX and Xvid errors
  • DivX and Xvid errors
    Posted by Nomar25 on January 28, 2006 at 1:26 am
    I downloaded the divx and xvid codecs and players and am working on vegas 5. I keep getting error messages whenever I try to encode my hdv clip with either one of these codecs. Maybe it’s my settings that I put in. Please help.
    Laszlo Kovacs replied 20 years, 8 months ago 2 Members · 3 Replies
  • Laszlo Kovacs
    January 29, 2006 at 6:15 pm
    I had successes with xvid.
    Could you give more info?
    Error message?
    Settings?
    By(t)e
    Laca
  • Nomar25
    January 30, 2006 at 6:45 pm
    Thanks for helping. I have Vegas 5d and got the xvid codec. I have an error message saying “An error occured during the current operation. An Exception has occured.” Vegas needs to be closed after that.
    My settings for my project are 1920 x 1080 with a PAR of 1.0 and in progressive. I am rendering an uncompressed AVI that has the same settings and applied color correction to it. I am rendering this out in order to view it on my HD Monitor that is 1920×1080 in square pixels. This is an animation type of clip too that is 10 seconds long.
    My Xvid settings are: Project is set at best quality with no audio. frame size is use project settings, NTSC frame rate, prog. scan, PAR of 1.0, Xvid MPEG-4 codec.
    The Configure tab of the codec sttings are: single pass, 1.0 target quantizer at 9600 kbps, unrestricted profile with MPEG type quantization with quarter pixel and B-VOPs checked and the aspect ratio of square 1:1.
    The quality preset tab settings: Motion search precision is 6 and VHQ mode is 4 and Use chroma motion is checked.
    In other options tab: FourCC used is “XVID”.
    When I start rendering it, after a couple seconds, Vegas crashes. I have rendered this same file out in WMV9 format and it looks good on the monitor. I heard this Xvid codec would give me better results. Please help. I have Xp64, Dell Precision 670, 2.8 GHz with 2.0 GB of RAM.
  • Laszlo Kovacs
    January 30, 2006 at 7:40 pm
    I need some time to investigate, to be in help for you, but:
    [Nomar25] “I have rendered this same file out in WMV9 format and it looks good on the monitor. I heard this Xvid codec would give me better results.”
    I really doubt this.
    I have rendered 352*288 25fps 256 kbps video using XviD-1.0.3-20122004.
    2 pass rendering.
    Vegas 5 built in 256kbps wmv resized to the same dimensions (352*288)
    gave MUCH better image quality.
    By(t)e
    Laca
