Activity › Forums › Cinematography › Diva Light – Kino
  • Diva Light – Kino
    Posted by Darkman on September 1, 2006 at 10:18 pm
    hi I’m new on here but have a problem with a kino and would appreciate any help. My diva light is a 4 bank 230v. I cannot get it to light all 4 daylight bulbs. It will light all 4 tungsten or 2 tungsten and 2 daylight but once I connect 3 or more daylight bulbs it only lights 2.
    anyone know whats going on?
    thanks
    Tim Kolb replied 20 years ago 4 Members · 4 Replies
  • Dan Brockett
    September 2, 2006 at 5:38 pm
    Hi:
    I would contact Kino Flo directly. Are you under warranty? Somethings not right. I would also try two different daylight bulbs in place of the ones that won’t light up.
    Best,
    Dan
    Providing value added material to all of your favorite DVDs
  • Tim Kolb
    September 5, 2006 at 1:23 am
    Yes…that was going to be my question as well…have you tried other daylight bulbs? …or have you tried to change the sockets around?
    If you trade the daylight and tunsten bulbs into the other’s sockets when you see the problem, does the problem stay with the bulbs or the socket?
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Bob Cole
    September 13, 2006 at 12:48 pm
    The Kino operates in pairs of bulbs. If there is a problem with one bulb (or its seating) then its pair won’t light either.
    Switch around as Tim suggested to isolate the problem to your one bulb, or to its seating.
  • Tim Kolb
    September 17, 2006 at 2:09 am
    I should have added…make sure that the connections are correct. We frequently have issues after re-lamping where the grip may inadvertently connect the ends improperly.
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
