Activity Forums Adobe After Effects Dithering in imported videos?
  • Kevin Camp
    August 30, 2007 at 7:20 pm
    i assume that this is what it looks like in ae preview window and not after rendering fro ae…
    it looks like a interlace issue… either the footage is interlaced and ae is not deinterlacing or the footage is progressive and ae in trying to deinterlace… from the looks i think it is the later.
    select the footage in the project window, then choose file>interpret footage>main… now check the separate fields pulldown… if it is set to upper or lower, set it to off. if it is set to off, try setting to upper or lower.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
