Activity › Forums › Apple Final Cut Pro Legacy › Distribution Amps
Distribution Amps
Posted by Smallfry on August 12, 2005 at 11:33 pmThe way I have my system configured, only my Beta SP deck and DVC Pro decks can be used for digitizing video without patching. Is it wise for me to use a distribution amp or switcher so I can use my various other peripherals to digitize video and audio. I am looking at A KRAMER 8×4 video switcher to use multiple sources to digitize into FCP and for mastering to the various decks and my DVD recorder after editing. Does anyone have any experiences with DAs or switchers used for this purpose??
Bouncing Account needs new email address replied 21 years ago 3 Members · 6 Replies -
Tom Matthies
August 12, 2005 at 11:42 pmIf you do buy a switcher for an analog system, get one that will switch your analog component signals (Y, R-Y, B-Y) into your computer. Try not to use composite video as a source for digitizing since the component signal is superior and will look much better.
Tom -
Smallfry
August 12, 2005 at 11:49 pmThanks for responding. Yes, I know about the composite vs. component issues. However, budgetwise, I have no choice at the moment. I was wondering if this switcher will work at all.
August 13, 2005 at 12:02 pmOf course you can use ANY properly operating composite Routing Switcher… if you are satisfied with composite video quality.
But today’s multitude of superior signal systems means that composite is usually the LOWEST quality transfer.Hence, many edit houses use passive Patch-Bays to take advantage of the highest quality signals at a much lower cost than equivalent (multi-format) Routing Switchers.
And there’s no worry that an “interior component” in an active Routing Switcher (most have many internal DAs) will degrade the signal (or fail outright).There are many configurations of Patch Bays that allow you to patch: composite, component, S-Video, SDI, FW, TC, audio, sync… anything that goes via a cable.
You send as many outputs/inputs as you want from/to decks, monitors, transcoders, DA’s and other gear to one central (well-labeled) patch-bay, and you can hook “anything to anything”.
Even locations that HAVE a routing switcher (left over from “all composite” days) just use it now to route to monitors in various rooms and for making VHS dubs and the like.
https://www.atis.org/tg2k/_patch_bay.html
https://home.flash.net/~motodata/patchbays/right.html
Smallfry
August 13, 2005 at 2:16 pmPatch bay is a great idea. Thanks. Unfortunately, while I am not satisfied with composite video, clients don’t get the concept and could care less about resolution. They are watching their projects on a low res TV and if it looks good, they are satisfied. Until I can afford a better capture system, composite is the way I have to go. Thanks for all the input. I appreciate it.
Tom Matthies
August 15, 2005 at 2:03 amDon’t necessarily pass on a patch system. There are loads of analog patch bays on ebay right now. You could probably pick one up for less than $100. Do a search on ADC and you’ll get some good hits. I have a Beta SP machine right in my edit room. Most of our source footage is shot on Digibeta these days. The rest of those sources come from a central machine room with inputs/outputs determined by good old fashioned patch bays. Don’t tell anyone, but I even run our SDI sources,(Digibetas, DVC with SDI cards, and the two other Avids) through analog patch bays. The runs are fairly short and it works.
Shhh…
Tom -
August 15, 2005 at 12:05 pm[Tom Matthies] “Don’t tell anyone, but I even run our SDI sources,(Digibetas, DVC with SDI cards, and the two other Avids) through analog patch bays. The runs are fairly short and it works.
Shhh…”No need to make this a “hush-hush” idea.
Using 75 ohm coax cable for SDI is just fine, and an “analog” patch-panel is built for that cable.
There are plenty of machine room patch bays with SDI connected just this way.
There is nothing “magical” about something that might be called a “digital cable” anyway.
The “high-end” cable scams run rampant.
