Activity Forums Adobe After Effects Expressions Distribute multiple layers between two End layers?
  • Distribute multiple layers between two End layers?
    Posted by Ocean Byrne on June 7, 2020 at 6:23 am
    Is there a quicker way to setup, or some help writing an expression, to distribute multiple layers between two End layers?
    • Ideally, it would work for 2d or 3d layers, and distribute pos / rot / scale / opacity.
    • It would be awesome if it automatically adjusted if you added or subtracted interim layers. Short of that, maybe the expression could start with variables like Order = 5 of Total = 15
    • It would be super cool if you could some how adjust “ease” on one End or the other, but just linear distribution between the two would be fine.
    • Finally it would be cool if it was easy to paste on to other channels like one’s in Effects or whatever one might want to interpolate from layer to layer….
    I understand the theory pretty well, but my syntax is crap. Help would be appreciated…
    Humble Pixel Farmer
    Ocean Byrne replied 5 years, 7 months ago 3 Members · 4 Replies
  • Dan Ebberts
    June 8, 2020 at 12:57 am
    I think this will distribute a property between two layers named “Start Layer” and “End Layer” (change the first two lines if your bookend layers have different names):
    startLayerName = "Start Layer";
    endLayerName = "End Layer";
    sStr = 'thisComp.layer("' + startLayerName + '")';
    eStr = 'thisComp.layer("' + endLayerName + '")';
    sIdx = eval(sStr + '.index');
    eIdx = eval(eStr + '.index');
    p = thisProperty;
    str = ".value";
    while(!(p instanceof Layer)){
    str = '("' + p.name + '")' + str;
    p = p.propertyGroup(1);
    sVal = eval(sStr + str);
    eVal = eval(eStr + str);
    linear(index,sIdx,eIdx,sVal,eVal)
    It assumes that the layers are contiguous in the layer stack, with “Start Layer” at the top and “End Layer” at the bottom.
    Dan
  • Ocean Byrne
    June 8, 2020 at 1:20 am
    What, no ease on the end layers? I kid. This is super AWESOME! Thanks so much Dan!
    _________
    Ocean Byrne
    Humble Pixel Farmer
  • Ocean Byrne
    June 22, 2020 at 10:40 am
    Is there a way to set a time offset on the start and end layer to be able to use this expression?
    I can adjust each layer manually to start 1 frame later than the previous, but it would be great to be able to adjust a slider on the End Layer and have them all interpolate between…
    Thanks again!
    _________
    Ocean Byrne
    Humble Pixel Farmer
  • Ocean Byrne
    February 3, 2021 at 10:02 pm
    Could have sworn I had figured this out, but not finding anything but this. How can I apply this same theory/expression to a channel within layers? Specifically I am wanting to blend between 2 animating shape lines. (they could be masks with strokes on them instead if that would work better.)
