Activity Forums Adobe Illustrator Distortion of closed paths
  • Distortion of closed paths
    Posted by Matthew Angus on October 18, 2015 at 10:11 am
    Hi guys
    Having some issues with paths in Illustrator that I have never encountered before
    As per the attached example, I’m noticing that some of the corners/joins are not joining correctly, creating a kink type of effect (a). However, when I copy and paste the same closed path shape, and move it above and to the left of the original path, it seems to correct itself (b).
    Bizarre, but hopefully someone could shed some light on this…as it’s only been occurring recently.
    Cheers, and thanks in advance
    Matt
    Matthew Angus replied 10 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
