Activity › Forums › Adobe After Effects › Distortion in Tame Impala’s Let It Happen
  • Kalleheikki Kannisto
    May 4, 2016 at 9:03 am
    Optics Compensation with Reverse Lens Distortion and Optimal Pixels gives you something very similar. You just have to scale it up to fill the edges.
    Also Bulge effect with negative values looks similar.
    For more detailed control, you can use Mesh warp with 3 columns and rows.
  • Nelson Ng
    May 4, 2016 at 10:33 am
    thanks, it does seem like fisheye with negative value does give a pretty similar look
