Activity Forums Apple Motion distorting the location line of a gradient
  • distorting the location line of a gradient
    Posted by Dan Gifford on November 28, 2017 at 5:59 pm
    Hello.
    I have a gradient, applied as an image mask, that I’m using to change the opacity of ONE side of a shape over time.
    It works – but as the bezier is a curve, I wanted to distort the ‘location’ (the name Motion uses to describe of the central point of the gradient) to fit the shape much better.
    I wandered if anyone could help me do this, or think of another way to achieve the effect?
    Thanks Dan
    Mac pro, motion 5, Elcaptian.
    Dan Gifford replied 8 years, 8 months ago 2 Members · 3 Replies
  • Simon Ubsdell
    November 29, 2017 at 10:36 am
    You could try using a Bulge to add some curvature the the gradient. Alternatively you could use a radial gradient but it would be less successful for what I think you want.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Simon Ubsdell
    December 4, 2017 at 9:08 pm
    Here’s a much better idea:
    Create two color solids one for each side of your gradient.
    Create a curved mask for the upper layer.
    Add a directional blur to the mask along the axis of the gradient and increase as required.
    Very controllable.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Dan Gifford
    December 22, 2017 at 7:49 am
    Thank you! I just tried it now, at the very end of the project and it worked really well. :o)
    Took me a while to work out exactly whet you meant, but I got it.????
