Activity › Forums › AJA Video Systems › Distorted signal through Kona 3
  • Distorted signal through Kona 3
    Posted by Naveen Mallikarjuna on August 4, 2010 at 10:04 pm
    So right now, I don’t seem to be getting any kind of proper signal coming out of my Kona 3 card (either with the BOB or multi-cable). External video just comes out as a pink solid color, sometimes with some dashed-line patterns through it.
    Audio is just a buzzing sound.
    Not only that, any attempt to send video to an external monitor causes FCP to freeze (pin-wheel of death).
    I upgraded to Snow Leapard and the 8.0 drivers.
    I am running:
    OS X 10.6.4
    FCP 7.0.2
    Kona 3 v8.0
    I uninstalled prior to updating to 8.0. I then tried another uninstall and reinstall. I updated the firmware as well.
    Any clues as to what might be going on? Help!
    Naveen
    Aja Sales department replied 16 years, 1 month ago 3 Members · 3 Replies
  • Bob Zelin
    August 5, 2010 at 12:54 am
    there is only one way to proceed.
    Stop using FCP.
    Do ALL of your test with AJA Control Panel. Click on control tab, click on test pattern – bring up color bars – do they look ok ?
    What VTR are you using ? Move the control tab in AJA Control Panel to INPUT PASSTHROUGH, and play your SD-SDI or HD-SDI thru the Kona 3. How does it look on your TV monitor ?
    Test everything with AJA control panel, and DO NOT use FCP until you are convinced that everything works with AJA Control Panel. You can even capture and playback a tape source with AJA VTR XChange (and not use FCP) to determine if the AJA card is working properly.
    Bob Zelin
  • Naveen Mallikarjuna
    August 6, 2010 at 12:16 am
    OK, I did the following (with FCP quit), and a Panasonic AJ-SD93 DVCPro deck connected:
    1. AJA Control Panel, Control Tab > Test Pattern.
    Result: A green, noise pattern appears on the monitor.
    2. Any other option except input passthrough (such as black).
    Result: Same thing, green noise pattern OR a black & white noise pattern.
    3. Input Passthrough
    Result: Success! I can see the video coming out of the deck, into the AJA breakout box, then back out to the monitor.
    4. Attempt to capture via AJA VTR Xchange.
    Result: At first, everything seemed fine. It could see the deck, play video (though it did not appear in the preview window). I started to capture and it seemed to work, until the end of the clip. It then gave me the following error:
    “Trouble Ending Record Operation. Error -2014”
    From all of this, I would guess that the card’s In and Outs work fine. The issue seems to be in the card’s ability to create an image/video. Does this seem right?
    Any suggestions as to how to remedy this?
    Naveen
  • Aja Sales department
    August 6, 2010 at 5:06 pm
    Naveen,
    I would suggest that you contact AJA tech support for assistance with your configuration. They will be happy to help you sort out your issue:
    https://www.aja.com/support/contact-support.php
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
