Activity › Forums › Adobe After Effects › Distorted parenting…?!
  • Distorted parenting…?!
    Posted by Johan Malmsten on September 24, 2009 at 2:06 pm
    Hi all!
    I’ve encountered this problem many a times in certain situations.
    When I build 3D-things in After Effects I usually do some parenting between different solids and the likes as we all do. The problem comes though when I have parented something to an object, and then I try to rotate the parented part. It’s dimensions goes amock and distorts in all ways and sizes! To the point that I can barely use it.
    As an example, here’s a link to an .aep that I made to test out some thoughts on a Motion Control Rig. Look at how it looks at the start and then run through the animation on the timeline. The only parameters that are animated are rotation-axis’es that are parented to each other to make up a pseudo-robotic arm thingy. The weirdest part is that the camera that is parented to the end of the arm distorts its output in an extreme way when it rotates around… I didn’t even know that that was even possible?!
    https://www.megafileupload.com/en/file/137955/Weird-distortions-aep.html
    Is there some way around this? Or is it something I need to live with unless I get a dedicated 3d-modeling programs? is the problem common at all?
    I’m using After Effects CS3 in a windows XP PC if it helps.
    Kira Ivanova replied 14 years, 7 months ago 2 Members · 2 Replies
  • Johan Malmsten
    October 17, 2009 at 8:29 pm
    So I take it that there’s no answer to this?
  • Kira Ivanova
    February 18, 2012 at 12:51 am
    Maybe this is due to the disproportional scaling of parent layer, which have caused the “distortion” of child layer.
