Distorted low audio levels
We installed the Ki-Pro in our studio to use as a recording deck.
We are running SDI and XLR into the unit.In CONFIG menu the settings are set to Analog Audio XLR at +24dBu and switched to LINE level.
XLR signal is coming straight out of Main L & R on our mixer, no processing or compression.
Toned and set levels using meters to 1st yellow light on Ki-Pro.
When recorded and played back in FCP or Quicktime the audio level is very low and sounds distorted. When played back through Ki-Pro, the audio sounds great.
Anyone have the answer I’ve been looking for?!
