Activity › Forums › Sony Cameras › Distorted audio on import
  • Distorted audio on import
    Posted by Craig Sawchuk on August 18, 2010 at 5:39 pm
    I thought I’d pick the brains over here as well as the Final Cut forum. I’m importing XDCAM files into latest ver of Final Cut and the audio is completely over-driven and distorted. The files play clean and well on the XDCAM transfer utility so I know that they are recorded well. Any suggestions would be much appreciated!
    Craig
    Craig Sawchuk replied 16 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
  • Craig Seeman
    August 18, 2010 at 6:00 pm
    Try listening to each channel separately. They may be summing. Try panning Ch1 left and Ch2 right.
  • Craig Sawchuk
    August 18, 2010 at 6:25 pm
    Tried that but the waveforms are just like building blocks and all that comes out is digital hiss.
  • Craig Seeman
    August 18, 2010 at 7:06 pm
    Try playing the clips (EX XDCAM .mov) in Quicktime. That’ll tell you if the problem is FCP specific. You may need to trash preferences.
  • Clint Fleckenstein
    August 18, 2010 at 9:28 pm
    Ditto on that. You’d be amazed at the way Final Cut (or a Mac in general, really) can behave when it gets a preferences file corrupted. Sadly it’s not a very rare occurrence. I just had a late night session where I had to push something out via Firewire and got nothing but digital garbage on both audio tracks (but video was perfect). You guessed it: preferences. There’s also some sort of MediaIO plist file that might have to hit the trash, too…depending on your issue.
    Cf
  • Craig Sawchuk
    August 18, 2010 at 11:18 pm
    Managed to get the audio back by opening the files in Soundtrack and then saving the audio to AIFF and reimporting them into FCP. Crazy… I will try the preference file replacement too.
    Craig
  • Don Greening
    August 19, 2010 at 6:05 am
    [Craig Sawchuk] ” I will try the preference file replacement too.”
    When you decide to do it go here first for a free program that will trash the preferences for you:
    https://www.digitalrebellion.com/pref_man.htm
    – Don
    Don Greening
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Rafael Amador
    August 19, 2010 at 11:18 am
    Craig,
    As per what you wrote in the FC forum, you should add here that you are try to work with MFX files in FC.
    Thats not the standard workflow. If you don’t tell the full story people won’t pick the full picture.
    rafael
    http://www.nagavideo.com
  • Craig Sawchuk
    August 19, 2010 at 11:27 am
    Good point. Aren’t XDCAM files MXF? I guess I was under the impression that they were one and the same once they are on the HD. Also the Sony import utility could play them flawlessly.
    Craig
