Activity Forums Adobe After Effects Distort effect
  • Distort effect
    Posted by William Saviola on March 9, 2010 at 4:36 pm
    Hello
    I am trying to find an effect i it has to be in distort somewhere, where i can create the oppersite effect f the bulge effect
    It can be done using CC cylinder however this is a long and annoying process and there must be a quicker method
    If i could go in to minus in the bulge effect this would be the answer however you cant go in to minus in the bulge effect
    Here is a example of what i want to do
    From my example you can see a the solid in the middle with this effect and it also has the small symbols tht are curving around to
    Thank you
    Darby Edelen replied 16 years, 5 months ago 2 Members · 3 Replies
  • William Saviola
    March 9, 2010 at 5:14 pm
    with the bulge effect you cant enter a negative value
    I have used the warp effect with the style set t bulge how ever even with the layer collapsed i am still getting some pixelated edges
    Would you know how to fix this with out blurring it ???
  • William Saviola
    March 10, 2010 at 3:31 pm
    Thanks Dave
  • Darby Edelen
    March 11, 2010 at 1:23 am
    This isn’t really any easier than using CC Cylinder, but I thought you might be interested to see how it works.
    I’ve included a link to an image that you can use with the Effect > Distort > Displacement Map effect on an Adjustment Layer at the top of your layer stack to create a cylindrical distortion. Try using 100 for the horizontal and vertical displacement.
    611_distort.psd.zip
    This image may need to be resized for your composition.
    Darby Edelen
