Activity Forums Apple Final Cut Pro Legacy DIssolving multiple key layers as one
  • DIssolving multiple key layers as one
    Posted by Ritchie Sax on August 5, 2008 at 10:30 pm
    Hello,
    I am having a problem dissolving key layers in and out from black. My problem is that I can see the key fading in with the dissolve. I would like to dissolve all layers up from black together. I’m sure there is an easy answer but I’m not finding it. I have tried the transitions in FCP Effects list but they don’t seem to do the trick, unless I’m missing the trick.
    Ritchie Sax replied 18 years, 1 month ago 2 Members · 2 Replies
  • Kc Allen
    August 6, 2008 at 1:56 am
    Two things you could do. You could NEST the various layers of the timeline and apply one dissolve to the group of layers. The layers are still editable by double-clicking the nest. The other thing is to place a black matte on your top layer and extend the end of the matte over the beginning of the video. Then simply dissolve out of that black matte into your video. Remove all transitions from the front of the video layers – since they’re behind the black matte, they’ll no longer be necessary.
    KC Allen
    Allen Film & Video
    “My name is actually spelled KC…really…it is…”
  • Ritchie Sax
    August 6, 2008 at 10:38 am
    KC,
    Thanks for the response. I tried it both ways. Nesting does work with the dissolve but I found my Live Type layer shifting at the end of the dissolve. One fix creates a new problem. So, I tried the matte layer and found that I could place a slug the length of my dissolve and change the opacity from 100 to 0 and that would act as a dissolve from color. AVID speak, I know, but it did the job. I wish there was a preset transition that did the job but you led me down the right road.
    Thank you,
    RItchie
