Dissolves in Excalibur 4.5
Posted by Jim Murphy on September 30, 2005 at 3:03 amI am using the trial version of Excalibur 4.5, using Multicam. (I’ve been using version 2 successfully for over a year.) I have the default dissolve set at 16 frames. The end result is straight cuts rather than dissolves. Any suggestions? TIA, Jim
Jim Murphy replied 20 years, 11 months ago 3 Members · 4 Replies -
Gary Kleiner
September 30, 2005 at 4:21 amMake sure automatic crossfades is turned on (Ctrl/Shift/x)
Gary
Edward Troxel
September 30, 2005 at 1:33 pmJim, e-mail me with more information and the VEG file in question. As long as all the markers are set up correctly, it should be dissolving unless the switch Gary mentioned is set wrong. It will help for me to see the VEG, though.
Also, note that there is a new version now available. Excalibur 4.6 can be downloaded now and has even more control over dissolves. The markers can be set as follows:
1d – Dissolve to camera 1 centered on marker (exactly the same as before)
1c – Cut to camera 1 (exactly the same as before)
1b – Dissolve to camera 1 with the entire dissolve BEFORE the marker
1a – Dissolve to camera 1 with the entire dissolve AFTER the markerThere’s also some other neat new features including the new Quick Label tool and some major enhancements to the Voice Over tool.
Check out the “What’s New in 4.6” link here: https://www.jetdv.com/excalibur
Jim Murphy
October 1, 2005 at 3:26 amEdward, thanks for looking at my veg file, and letting me know what I did wrong, not using the markers the way Excalibur 4.5 is designed to handle them. I appreciate you generosity and willingness to solve these “mysteries” for me. Jim
