Activity Forums Apple Final Cut Pro Legacy Dissolves and text skip frames when rendered
  • Dissolves and text skip frames when rendered
    Posted by David Jakubovic on February 15, 2010 at 4:36 pm
    Very strange glitch: footage shot on P2, 720p 24N. Working with FCP 6.0.6
    When I put a dissolve on the footage, it plays fine as long as it is not rendered. As soon as I render it, there is a strange jump right at the very beginning or the very end of the dissolve. Same goes for text tool. The glitch even shows up when going frame by frame.
    I tried trashing all render files and re-rendering. I tried duplicating sequences, creating new sequences and putting it in to new timelines – all that. Sometimes the problem seemed to go away but then it started again.
    Anyone ever had this problem?
    David
    “We’ll fix it in post”
    David Jakubovic replied 16 years, 7 months ago 2 Members · 2 Replies
  • John Fishback
    February 15, 2010 at 10:38 pm
    Read David Roth Weiss’ post in this thread.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • David Jakubovic
    February 16, 2010 at 3:21 am
    Oh, believe me, I did what he suggests in that post very early on. Nothing work. The workaround I found was to export the clips on which I was doing effects, bring them back in and then do the effect – it worked perfectly then. Very strange.
