Activity › Forums › Maxon Cinema 4D › Dissolve/Morph Material
  • Dissolve/Morph Material
    Posted by Angel Nieves on January 24, 2020 at 3:44 am
    I’m trying to dissolve or morph the material or UV mapping and can’t seem to do it. I morphed two simple objects from the same sphere. I created a sphere and copied it, then distorted the second sphere. I morphed them using pose morph. That worked fine. But I have no idea how to also morph the material. The shape is supposed to change shape and color/texture. I want the texture to change through a dissolve and not a gradient reveal. I would appreciate your help or to be pointed to a tutorial. Thanks!
    Sam Treadway replied 6 years, 8 months ago 2 Members · 1 Reply
  • Sam Treadway
    January 25, 2020 at 1:44 am
    Use a layer shader and load in two textures/shaders as layers and animate the blend by setting keys for the entire layer shader while inside that view.
