Activity Forums VEGAS Pro Dissolve Transition Problem
  • Dissolve Transition Problem
    Posted by Tonys on April 17, 2005 at 1:31 am
    I have two clips butted up next two each other and would like to add a dissolve transition, by placing my cursor in the centre of the two clips and dragging a transition from the transition window, I thought a transition will overlap the two clips automatically & create a cross fade/dissolve, however this doesn
    Edward Troxel replied 21 years, 5 months ago 2 Members · 7 Replies
  • 7 Replies
  • Edward Troxel
    April 17, 2005 at 1:51 am
    Did you turn off “Automatic Crossfades”? It’s one of the buttons on the toolbar.
    Edward Troxel
    JETDV Scripts
  • Tonys
    April 17, 2005 at 2:14 am
    Edward, that is defiantly active. If I drag the clip from the right over the clip on the left, it defiantly creates a cross fade, What it wont let me do is place two clips next to each other and allow me to right mouse click add transition.
    Is there anything else you can think of?
  • Edward Troxel
    April 17, 2005 at 2:16 am
    You have to create the overlap. If you want, you can put the cursor between the clips and press “/” on the numeric keypad.
    Edward Troxel
    JETDV Scripts
  • Tonys
    April 17, 2005 at 3:35 am
    Correct me if I
  • Edward Troxel
    April 17, 2005 at 3:46 am
    It will actually extend both events to create an overlap by the amount you have set in the preferences.
    Edward Troxel
    JETDV Scripts
  • Tonys
    April 17, 2005 at 4:29 am
    Edward, In preferences/edit/cut-to overlap conversation was set to 0, I set that to 1.000 & it works perfect.
    Thanks heaps.
    The other question I have is where can I find the crossfade transition? It doesn
  • Edward Troxel
    April 17, 2005 at 1:26 pm
    The crossfade is simply the “automatic” transition when you overlap two clips. The transitions are something you can use to REPLACE the auto-crossfade. I know of NO way of getting back to the auto-crossfade than right-clicking the transition and picking “Crossfade”.
    Edward Troxel
    JETDV Scripts
