Activity › Forums › Apple Final Cut Pro Legacy › Dissolve In or Out from Empty track to Video in Fullscreen
  • Dissolve In or Out from Empty track to Video in Fullscreen
    Posted by James Curry on February 27, 2010 at 6:25 am
    Just curious as to why sometimes FCP doesn’t read a Cross Dissolve in Fullscreen as a fade up or down when its placed on an empty track and “fading” either into or out of an image? Also curious why some dissolves cause a one or two frame jitter or jump (even when fully rendered) in the Timeline and Fullscreen. Both of these issues seem to be intermittent but possibly linked linked to the “All Frames” setting when using Digital Cinema Desktop Preview. Any thoughts?
    James Curry replied 16 years, 7 months ago 3 Members · 4 Replies
  • Josh Olenslager
    February 27, 2010 at 5:18 pm
    I always use the pen-tool and opacity when fading in from empty tracks. I’ve occasionally seen what you’re describing in the crossfade/dissolve presets–sometimes it was related to mixed format footage (and depending on the timeline settings the fade could be strained). Sometimes I’ve just thought it was a glitch. Anyway, try setting your fade using the opacity w/keyframes. It’s worked for me.
    Josh
  • John Fishback
    February 27, 2010 at 8:17 pm
    That dissolve “bump” is often caused by the dissolve not being fully rendered. Checkout this post by David Roth Weiss.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • James Curry
    March 3, 2010 at 2:57 pm
    Thanks John, I’ll check it out.
  • James Curry
    March 3, 2010 at 2:59 pm
    Your right. I’ve become so accustomed to dropping them in via the default keys that I forget I can resolve the issue with a manual fade just as easily and minus any side effects. Thanks Josh.
