Activity Forums Maxon Cinema 4D Dissolve all the edges once?
  • Dissolve all the edges once?
    Posted by Jun Tanaka on August 6, 2015 at 11:58 am
    Any tip to dissolve all the edges easier?
    In polygon mode, it would be a little bit easier to erase multiple edges once.
    However the model is huge and has too many lines to be dissolved.
    Even the polygon mode is tedious.
    Any advices would be much appreciated.
    Best regards, Jun
    Jun Tanaka replied 11 years, 1 month ago 3 Members · 3 Replies
  • Adam Trachtenberg
    August 6, 2015 at 9:34 pm
    You’ll probably want to use a combination of tools to select the edges. First, you can convert a polygon selection into an edge selection by Ctrl + Clicking on the edge mode icon.
    Problem with that is you’ll have the border edges and not just the internal ones selected, so you’ll have to deselect the borders. You can use the phong break selection tool to help with both.
    The path selection tool can be very helpful for picking edge loops where the actual edge loop tool doesn’t work. Set it to live path mode and drag to create your selection (or hold down Ctrl to deselect). You can select a border of edges and then use the fill selection tool to pick the polys inside.
    Unfortunately there’s no one-button solution.
  • Brian Jones
    August 6, 2015 at 10:20 pm
    the still-selected border edges can be deselected by using the Outline Selection Tool with the Cmnd key (what is it in Windows? Cntrl?) to subtract from the selection
  • Jun Tanaka
    August 14, 2015 at 3:35 pm
    Adam and Brain,
    It seems working. I will do my best. Thanks, Jun
