Activity › Forums › Apple Motion › dissapointing 3d layer
  • dissapointing 3d layer
    Posted by Andi Novianto on January 4, 2009 at 3:21 pm
    i’m using apple motion 3.0.2 and i have a kind of problem with the 3d layering. In my scene i create 3d composition. There are a background layer and a foreground layer. The foreground layer is positioned in front of the background , the foreground is a group consist of 2 object -> a black/white image (to be used as the alpha) and a texture image. I used stencil luma for achieving the effect. I set my camera flying to get closer to the foreground then pass through the transparent area of the foreground. The preview is having no problem, but when i render it out using ‘best’ quality mode, as the camera went through the transparent area of the foreground. the layer is became solid. But it’s not a problem if my camera is not to close to the layer. And this is only happen in the ‘best’ quality render, not the other mode. And this problem won’t show up in the ram preview.
    so far i have no solution, the only thing i can do is render the whole using ‘best’ quality render, then render using ‘normal’ quality for the part where the camera fly through the transparent area of the foreground. Then i edit them using fcp.
    anyone has any experience with this?? this is so bad 🙁
    thanx
    Andi
    David Bogie replied 17 years, 9 months ago 2 Members · 1 Reply
  • David Bogie
    January 4, 2009 at 6:12 pm
    See my response to your same post at apple.com
    bogiesan
