Activity Forums Maxon Cinema 4D Dissable reflections partially
  • Dissable reflections partially
    Posted by Cristi Dinu on March 3, 2015 at 3:06 pm
    Hello everybody,
    Been fidgeting with Cinema 4D for a few days and I’ve been modelling two spinning dices on cylinders sitting at a relative distance as a practice run. Now, I’ve applied a reflective metallic texture on the cylinder to be able to have a reflection from the above dice but after a quick render, I saw that the other dice and cylinder was reflecting into the first cylinder as well. How can I maintain the reflection for the object above but stop it for the ones in vicinity?
    Adam Trachtenberg replied 11 years, 6 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    March 3, 2015 at 4:47 pm
    Add compositing tags to the objects that you do not want to appear in reflections. Go to the tag’s Exclusion tab and drag the reflective objects into the link box.
  • Cristi Dinu
    March 4, 2015 at 9:48 am
    Thank for the quick reply.
    Still getting used around the Cinema 4D interface so I wasn’t able to locate the Exclusion tab you are mentioning. Is that present in the attribute manager of each individual object?
  • Adam Trachtenberg
    March 4, 2015 at 11:06 pm
    First you need to add the compositing tag to your objects — the one’s you want to exclude. Then click on the tags and look at the attributes manager. Exclusion is one of the tabs at the top.
