Activity Forums Apple Motion displaying source timecode in Motion
  • displaying source timecode in Motion
    Posted by Peter Mcauley on September 23, 2005 at 3:12 pm
    I exported a reference quicktime from FCP 5. I imported it into Motion. Is there a way to display the original source timecode in motion. I created a mask and imported the Motion project back into FCP. The clip does not maintain its original code. Is there a way for Motion to read and maintain the original source and have it sent back to FCP?
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.4.2
    FCP 5.02
    QT 7.02
    Kona 2 v1.2 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
    Andy Edwards replied 20 years, 11 months ago 3 Members · 2 Replies
  • Jim Kanter
    September 23, 2005 at 6:42 pm
    Why not do an ‘edit in external editor’ from within FCP?
    As far as I know, Motion projects are treated like new QT clips so they would have their own TC. Might be a good suggestion to Apple to allow the user to assign a custom starting TC for a project.
    Greg?
  • Andy Edwards
    September 24, 2005 at 2:25 am
    If you are just doing tests for your grahics, try the timecode read filter in fcp. Export your movie with that applied. Tweak everything you need in motion with the timecode burned in. Once you have everything you need, replace the original media in your motion project with out the time code reader filter applied.Seems like a lot of steps, but at least you will be able to see the original time codes.
    Andy
