Activity › Forums › Apple Final Cut Pro Legacy › Displaying frame information
  • Displaying frame information
    Posted by Nathan Norrgran on October 4, 2010 at 7:58 pm
    Hello.
    Does anyone know of a Plugin that would be able to display frame information, specifically the name of the source video, over my clip? Noise Industries FxFactory has a plugin close to this, but it lacks the whole source clip info I am looking for.
    Andreas Kiel replied 15 years, 11 months ago 4 Members · 3 Replies
  • Philip Hodgetts
    October 11, 2010 at 12:25 am
    We just released Clip Info Reporter https://assistedediting.intelligentassistance.com/ClipInfoTitler/ in response to a request from the Cow’s Shane Ross. It was released earlier this week and should do what you need. Or we’ll make it do what you need!
    Philip
    Philip Hodgetts
    https://www.proapps-hub.com
    The ProApp-Hub: The convenient way to the best of what’s free and everything else you need to be productive and creative with Apple’s Professional audio and video Applications
    Download Now proapps-hub
  • Andy Mees
    October 11, 2010 at 12:56 am
    Hi Nathan
    If it’s specifically the name of the source clip you need then an XML based solution like Andreas Kiel’s “TCR Plus” or Philip’s “Clip Info Reporter” are your only options, no method other than using XML is currently provided inside FCP to return that info. TCR Plus is here : https://www.spherico.com/filmtools/tcrPlus/index.html … not free, it costs about 60 bucks.
    Best
    Andy
  • Andreas Kiel
    October 11, 2010 at 10:04 am
    Just to clarify a bit.
    For the automated display of clip names (or other things) you need XML as Andy said and therefore need an app to process and spend some bucks.
    For the manual way you can use the TCR Plus filter inside FCP for free.
    Regards
    Andreas
    Spherico
