Activity Forums Maxon Cinema 4D Displaying an Object’s Rotation Values and the Timecode in a Realtime MoGraph Text Display
  • Displaying an Object’s Rotation Values and the Timecode in a Realtime MoGraph Text Display
    Posted by Hayden Martin on September 23, 2014 at 3:09 pm
    Hi Guys
    How do I assign the changing numerical values of an object’s rotation to a real-time MoGraph Text display?
    I need to send data from a virtual robot’s axis values to a programmer who will input the values to a real robot.
    I also need the real-time timecode in a 30fps format to be created in MoGraph text too…
    Brian Jones replied 12 years ago 2 Members · 3 Replies
  • Brian Jones
    September 23, 2014 at 4:55 pm
    in xpresso feed the rotation you want to watch through a Degree node (set to Radians to Degree) to the Object Properties/Text port of the MoText object. If you don’t know xpresso I can send an example.
    The time is easy enough if you want frames – same thing feed the Frames port of a Time node the the MoText Text port but if you want seconds:frames it’s trickier as the Time node doesn’t have a SMPTE out. But it can be constructed. What time output do you need? Just the frame number or something more complex?
  • Hayden Martin
    September 23, 2014 at 5:03 pm
    Ah thanks Brian
    It’d be great if you can show me an example
    And yes, i do need seconds & frames! Cheers
  • Brian Jones
    September 23, 2014 at 6:34 pm
